Glanza AuA Posted July 21, 2012 Share Posted July 21, 2012 (edited) high guys ever since i changed to a civic dual core radiator my slim fan seems to take to long to shut it self off. i'm not having any overheating or coolant loss either so i was just wondering if this is normal when you go civic radiator ?? i do have the fan in the right position thus blowing air toward the engine bay!! just like the oem one. here in Aruba is 24/7 hot every day so we dont have winters,maybe that have something to do with the fan staying on longer than the oem rad ??also my rad hose seems to get harder after some hard driving? noticed on my friends oem rad type hose seems to be a lot softer ?? my rad came with a 1.3bar cap don't know it this can cause extra pressure in the system ?will appreciate the help thanks guys Edited July 31, 2012 by Glanza AuA Quote Link to post Share on other sites
Glanza AuA Posted July 21, 2012 Author Share Posted July 21, 2012 anyone Quote Link to post Share on other sites
grum-glanza Posted July 21, 2012 Share Posted July 21, 2012 maybe you have might have a sticking thermostat replace it and see if the fan still says on as long, its possible the rad isn't big enough the keep the car as cool as the oem rad Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 thx for the reply,thermo was changed 1 week ago with a oem one!! Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 damn it drove hard today and its overheating now but only under boost Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 radiator seem to be building to much pressure inside,can it be head gasket ?? i'm not losing oil or coolant and there seem no oil and coolant mixing eitherdamn it Quote Link to post Share on other sites
Johnboy GT Posted July 22, 2012 Share Posted July 22, 2012 Try changin your rad cap to a 1.1 bar one instead?John Quote Link to post Share on other sites
Whitegv Posted July 22, 2012 Share Posted July 22, 2012 If its pressurising the system id say there's something wrong with the hg. it may be getting a tiny bit of head lift on boost.What turbo and boost are you running? Quote Link to post Share on other sites
pick1 Posted July 22, 2012 Share Posted July 22, 2012 Flush it out re-place the coolant bleed it and see how it goes u may need a triple core rad to attempt to combat the heat u lot experience Quote Link to post Share on other sites
Asad Posted July 22, 2012 Share Posted July 22, 2012 Whats the ratio of water:antifreeze? The top hose will be hard till the stat opens up iircIs it throwing coolant back into the overflow? Give it a hard drive, open up the bonnet and check how things are ticking over Higher pressure rad caps are better, higher pressure = takes more to boil the water but the rest of the cooling system should be up to par Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 hi guys sry for the slow reply time difference from our country is a bit pain Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 Try changin your rad cap to a 1.1 bar one instead?Johni just ordered a 1.1 from ebay will try that once it arrives Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 If its pressurising the system id say there's something wrong with the hg. it may be getting a tiny bit of head lift on boost.What turbo and boost are you running?im also thinking its the head gasket, im running a TD04l 0n 10psi boost blitz access,will up the boost once a get the fueling checkedalso did a comp test yesterday came 170 172 172 172i also just bought a cometic head gasket as last resort Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 Flush it out re-place the coolant bleed it and see how it goes u may need a triple core rad to attempt to combat the heat u lot experiencedid that like 3 times already make sure every air is out util no bubbles still dont know why it overheats only when boosting and the fan doesn't turn off once it starts should the td04 water line be off could that be making to much stress on the dual core ?? Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 (edited) Whats the ratio of water:antifreeze? The top hose will be hard till the stat opens up iircIs it throwing coolant back into the overflow? Give it a hard drive, open up the bonnet and check how things are ticking overHigher pressure rad caps are better, higher pressure = takes more to boil the water but the rest of the cooling system should be up to parhi i must admit i'm using just a regular red coolant from Toyota don't need antifreeze here in Aruba!!both of my top and lower hose seems to get quite hard once warmed upper one warms first tough, ever since i installed the dual radiator it only overflowed once, never did it again its like its no working checked bottle hose and they seem fine not blocked!i did some hard driving yesterday but i only manage to get it overheat and the over flow bottle stays the sameas soon i let go of the gas it cools it self back again but fan stays on! Edited July 22, 2012 by Glanza AuA Quote Link to post Share on other sites
Glanza AuA Posted July 22, 2012 Author Share Posted July 22, 2012 (edited) by the way guys it doesn't overheat all the way in the red zone because once i let go of boost it goes back no normal tempi can ride all day within normal temp when off boostits just a pain i think i'm gonna do the HG Edited July 22, 2012 by Glanza AuA Quote Link to post Share on other sites
Glanza AuA Posted July 29, 2012 Author Share Posted July 29, 2012 (edited) hi guys just an updateapparently my dual core rad was blocked,i now have a new one with a 1.3cap on it,it doesnt overheat anymore but the rad hose still gets quite hard like under pressure ?is this normal both the upper and lower ? Edited July 31, 2012 by Glanza AuA Quote Link to post Share on other sites
Glanza AuA Posted July 31, 2012 Author Share Posted July 31, 2012 bump anyone?? Quote Link to post Share on other sites
pick1 Posted July 31, 2012 Share Posted July 31, 2012 Under hard boosting I believe that is pretty normal for them to build up some pressure and go slightly hard as your pushing the engine more getting it hotter and increasing water flow to try and cool it just keep an eye on it mate but if the temp ain't climbing anymore u may of cracked it Quote Link to post Share on other sites
Glanza AuA Posted August 1, 2012 Author Share Posted August 1, 2012 Cracked it ? You mean the head ? Quote Link to post Share on other sites
Glanza AuA Posted August 1, 2012 Author Share Posted August 1, 2012 anyone else ? Quote Link to post Share on other sites
The Toffinator Posted August 1, 2012 Share Posted August 1, 2012 Rad hoses will go hard buddy as the pressure increases. If its not drinking water and not spewing it out and not overheating it will be fine. Quote Link to post Share on other sites
Fozzie Posted August 1, 2012 Share Posted August 1, 2012 Under hard boosting I believe that is pretty normal for them to build up some pressure and go slightly hard as your pushing the engine more getting it hotter and increasing water flow to try and cool it just keep an eye on it mate but if the temp ain't climbing anymore u may of cracked itI think he means 'cracked it' as in 'sorted the problem out' mate Quote Link to post Share on other sites
Glanza AuA Posted August 1, 2012 Author Share Posted August 1, 2012 thx a lot for the reply guys i will keep an eye out,as everything seems normal now... Quote Link to post Share on other sites
pick1 Posted August 1, 2012 Share Posted August 1, 2012 Yes mate I ment as in sorted the problem Quote Link to post Share on other sites
