in an out movement on the driveshaft? as in where the CV joints are? Yeah thats normal. There shouldn't be in and out movement between the cv joint and diff. But there will be between the cv joint and drive shaft if you get me?
Just watched the vid thats just it moving until it hits the circlip that holds the cv joint in the diff. You wont get that when its in the car pressure between the box and the hub will hold that.
yer ive got that which is normal but on the video you can see the movement between the cv and gearbox (diff)
Apoligies didnt notice the vid lol.
it still shouldnt be that much movement, on the shaft, in and out the gearbox, there should be minimal movement, even when its out the car,
could well be dude, take the shafts out, and see how much movement you get, stick your fingers in there and see if there is lift, and side to side
