white-gt Posted July 26, 2012 Posted July 26, 2012 Right guys, ive been having some creeping issues where its going from 15psi to about 17psi at times, and althought i run a dastek and all the supporting mods im just concerned of blowing the bitch up..i have provided my dyno sheet for you to look at and let me know from your calculations if you think it will be safe with this creep or not.many thanks! Quote
TrisK Posted July 27, 2012 Posted July 27, 2012 (edited) everything looks okyour fuelling is a bit rich but i wouldnt be worrying Edited July 27, 2012 by TrisK Quote
Flaminsam Posted July 27, 2012 Posted July 27, 2012 Yup I agree. Some fine tuning should sort the afr, thing is it could be running rich to help keep the bore temps down and to prevent detonation. Quote
white-gt Posted July 27, 2012 Author Posted July 27, 2012 So boosting to about 17psi will b fine? It was originally set with a hybrid which will be back on at some point. If u guys say I'm running abit rich then surely boosting to 17 is gonna be fine ? Guys its the blue line not the red, just so u know Quote
TrisK Posted July 27, 2012 Posted July 27, 2012 (edited) well your fuelling looks ok on that graphbut that graph doesnt show anything above 14ish psi of boost Edited July 27, 2012 by TrisK Quote
white-gt Posted July 27, 2012 Author Posted July 27, 2012 It's tiny bit under 15.. if it was at its optimum I would say its risky but if u guys say its a bit rich ... I dunno.. Quote
