Amz09 Posted July 27, 2012 Posted July 27, 2012 Hi was wondering if anyone could point me in the right direction as 2 where I can find the cps? The reason I'm asking is I have a problem with my rev counter not working and I was told it might be due to the crank position sensor being faulty. As the rev runs off of this.. Is that correct?Any info from you guys would be very helpful. Quote
joel_ep91 Posted July 27, 2012 Posted July 27, 2012 revs run off the dizzy as far as i remember, there is no crank sensor on starlets Quote
joel_ep91 Posted July 27, 2012 Posted July 27, 2012 well you either took that off one of the very late ep91 N/A's that had coilpack rather than dizzy or its custom lolim going to go with custom to run with your standalone ecu ? Quote
Amz09 Posted July 27, 2012 Author Posted July 27, 2012 Thanks for quick replys guys. Bean, I duno wether 2 turn my screen 2 one side or what lol.. Where is that?Ok..so any idea what would be the best way forward? When you say off the dizzy, is there a sensor situated within or wiring? Sorry I'm abit stumped and need help as its really fobbing me off now I had the engine check light come on at 1 point when it all happened if that's any help. Quote
Amz09 Posted July 28, 2012 Author Posted July 28, 2012 If anyone can help, what would be the first steps you would take if you had this problem?? Quote
Johnboy GT Posted July 28, 2012 Posted July 28, 2012 In beans photo its the drivers side of the engine at the bottom however its custom so not as standard.By all means check and see. John Quote
Bean Posted July 28, 2012 Posted July 28, 2012 If the ecu light came on check for fault codes that might point you in the right direction. Quote
Amz09 Posted July 28, 2012 Author Posted July 28, 2012 Cheers lads. The only thing with the ecu light is once I turned the car off and started it up again it wasn't to be seen. And hasn't come on since. So if I was to check for fault codes I guess nothing would come up =\ Quote
AdamB Posted July 28, 2012 Posted July 28, 2012 If the EML light was on for 30 seconds or more it would have stored a fault code. Quote
