Starbo Posted June 11, 2007 Posted June 11, 2007 I know its got to be far from acurate but does anyone know what the lights are roughly?I.e 1st light - ...Psi/Bar2nd light - ...Psi/Bar3rd light and beyond...lol - Quote
ecksjay Posted June 11, 2007 Posted June 11, 2007 get a boost gauge.i've got a hks one if you need one, £35 posted. Quote
Starbo Posted June 11, 2007 Author Posted June 11, 2007 I know i need one! I'm just mega skint this month as i go on hol on the 30th! (Its Tom16v by the way...)I've found today that the actuator feed looks like its got a slight hole in which is worrying to say the least. HOwever i have replaced it and it feels no slower so hoepfully it wasnt leaking causing increased boost! Quote
Starbo Posted June 11, 2007 Author Posted June 11, 2007 Oh and i was thinking about lowering the boost on the actuator to the second light until i can afford a boost gauge/controller.Provided the second light isnt stupidly low boost? Quote
WallaceGlanza Posted June 11, 2007 Posted June 11, 2007 3rd light is 9psi ie stock hi2nd i think is about 6psi 1st comes on when you start making boostAs ecks said get a proper one though. Quote
StarletRick Posted June 11, 2007 Posted June 11, 2007 1st light is about 2psi2nd is about 5. 3rd comes on at about 7psiroughly ;]but, get a gauge. Quote
Glanza_Ragger Posted June 12, 2007 Posted June 12, 2007 Dont drive it as much, save the cash that would go on the extra fuel and buy a boost gauge only way to tell ..The lights wont be accurate at all.And replace the actuator hose that has the hole in, it will be leaking boost under pressure. Quote
