Driver Posted August 12, 2012 Posted August 12, 2012 ^^^ don't doubt that but is his car mapped for closed loop???????Nope but will be as he is having it mapped by same tuner as me he was saying on PMs Quote
Wardy Posted August 13, 2012 Posted August 13, 2012 Check out tuning developments as i found they were the cheapest around at the moment and also running without one will cause your fueling to be all over the place, could run rich and burn out you piston rings or could run lean and put a hole through you piston....Your choice matey Quote
R.Player Posted November 24, 2012 Posted November 24, 2012 i decated my sportif and replaced the cat with a small silencer and broke one of the lambda wires by accident and then i couldnt get it to fit propperly for some reason .. cant remember properly now was a while back but i ended up cutting the lambda wires and leaving it ..... end result idles at 2k at 6 in the morning when its cold(sorry neighbours) randomly had rough/ fluctuating idle. and every now and then mostly after pinning it the check engine light comes on may be a different case on a turbo but id put it in people think im revving my engine when im just sitting at the traffic light waiting to go Quote
