No 1 bar is natural pressure above sea level which takes up that pressure form the sensors range
So going above 2 bar is tricky with a 3 bar sensor
Is what has been explained to me
Edited by yaristurbo
After doing some sums I've come up with the same as socks????? Why would my engine builder recommend more?
As natural pressure is not a bar
Just looked for a reading and barometric pressure has reached 1011milbar just over a bar today so this could be the reason
Technically yes atmosphere is a bar but most sensors for cars will be set to read 0 at atmosphere as its neutral and works as a standard to go by so 3 bar would be fine upto 44ish psi which usually more than enough
Will go mapping with my 3 bar and let you know if I need a 4 cheers team
ull need to completely re-scale the entire map if u do that, so best to start with the 4bar... but tbh id be very suprised if u need to run over 2bar of boost. i would think on pump fuel ull find a wall with another componant!
