Stroudy Posted August 17, 2012 Posted August 17, 2012 Anyone know what could be causing this??/>http://i600.photobucket.com/albums/tt85/stroudy_2009/BB603C33-DD2E-4579-A425-44D4A564A630-1269-0000015BA283D5A6.mp4 Quote
russ78 Posted August 17, 2012 Posted August 17, 2012 check the pipe that goes from the PCV valve on the rocker cover, to the inlet manifold it may well have come off or be split Quote
DaveyDemolition Posted August 17, 2012 Posted August 17, 2012 Yeah mine was doing the exact same when I changed the inlet manifold and there was a vacuum leak from the inlet to the throttle body, so I would check all your pipes etc Quote
Stroudy Posted August 17, 2012 Author Posted August 17, 2012 Cheers guys, ill try out wots been said and let you know how it goes ;) Quote
lew777 Posted August 18, 2012 Posted August 18, 2012 Does the problem go away when your driving? Quote
