jonnygt Posted August 21, 2012 Posted August 21, 2012 Managed to get a engine from a auto glanzaWill it fit straight into mine, even tho mines manuelI know i have to change clutch and flywheel etcEverything else the same tho??Thanks!!! Quote
micky boy Posted August 21, 2012 Posted August 21, 2012 Like i said on FB just the TPS as far as im awere if anyother sensors differ then just swap them over Quote
jonnygt Posted August 21, 2012 Author Posted August 21, 2012 Nee worries bud. Nice one! Ill have a good look when i compare them : ) Quote
jonnygt Posted September 12, 2012 Author Posted September 12, 2012 New engine is in! Still not running right. The TPS sensor from my manual has been swopped onto the auto engine so it works in mine! Its not running right tho but that is the only problem, its been diagnosed that thats the problem. Anyone know anything else it could be? Will i need a different throttle body/sensor? Need it sorting asap Thanks Quote
jonnygt Posted September 13, 2012 Author Posted September 13, 2012 Sorted now anyways! Thanks lads Quote
