Anybody know if its just a matter of taking of the belt and engine mount jacking up that side of the engine and taking this out or can they be a pain in the arse?
Cheers
Might be worth doing the seal while it's apart both mine came off with a light tap. Only 5 bolts to undo. Make sure you replace with a genuine one heard storys of aftermarket ones failing.
Rob
Yeah i would have done that mate was just gna get it from idrees. Is it just a case of what i said removing the engine mount and whipping it off? Just wanted to make sure i wasnt gna go out and do it and be unable to get it done.
The water pumps I have are made by AISIN, the same brand who make the original oil pump for Toyota.
I've sold plenty and no comebacks.
