jonnygt Posted September 12, 2012 Posted September 12, 2012 Ive recently put a auto engine into my manuel glanza. Got told to keep the tps sensor from my manuel and use it on the auto engine otherwise it wouldnt work. This has all been done but its not running right with the tps sensor and the throttle body. Will i need to use the throttle body from the auto engine?? Cheers Quote
turbo Grant Posted September 12, 2012 Posted September 12, 2012 You will need a manual tb and manual tps sensor. The manual throttle body uses a D shape pick up for the sensor and the auto uses a 2 prong pick up Quote
jonnygt Posted September 12, 2012 Author Posted September 12, 2012 Yeah thats what ive got from my manuel engine. Both throttle body and tps sensor. But its still not right. Unless they have left the auto throttle body on with manuel tps sensor. Would it still start and drive if this was the case? Just its lumpy and not going over 3000rpm ? Quote
turbo Grant Posted September 12, 2012 Posted September 12, 2012 My car was doing that when I had mine in plugged. There is a tps sensor set up over on tgtt Quote
corofin12345 Posted September 12, 2012 Posted September 12, 2012 (edited) how many wires does your loom have going to TPS? Edited September 12, 2012 by corofin12345 Quote
