har-vey Posted September 17, 2012 Posted September 17, 2012 fitted with 215/40/16. will i have any issues on my ep91? Quote
zebedee Posted September 17, 2012 Posted September 17, 2012 I'm on 16x7 et28 and with a 195/45 i've had to have the rear arches rolled to get clearence fronts were ok on the stock wings i'm now using cruise wings and plan to space the front a bit futher out. Quote
har-vey Posted September 17, 2012 Author Posted September 17, 2012 i plan on rolling the arches so i should be ok? Quote
zebedee Posted September 17, 2012 Posted September 17, 2012 A 215 is 20mm wider than a 195 so would be 10mm further out than a 195 so it's going to be tight, what about a 215/40 on the front and a 195/45 on the back they would work out at the same overall diamter pretty much. Quote
har-vey Posted September 17, 2012 Author Posted September 17, 2012 the only reason for that size tyre is because the wheels im looking at have them already fitted.does anyone know the thinnest pcd adapters i could get away with. i know on the celica its 27mm Quote
TrisK Posted September 17, 2012 Posted September 17, 2012 what PCD are you adapting to and from?if they have that offset without adapters there is no way they are fitting Quote
har-vey Posted September 18, 2012 Author Posted September 18, 2012 5x100 and no that is with the adapter on Quote
zebedee Posted September 18, 2012 Posted September 18, 2012 (edited) You'll be looking at custom built adapters for that as i was going to do it.All the ones you will find listed are for cars with bolts not studs like the vag stuff which is all bolt.Best way i could think to do it was use one long stud that would go from the hub through the adapter and pick up one hole in the wheel then do the other with the adapter but you might have to cut your studs short due to them hitting the back of the wheel and then use bolts for the other 4 holes holding the wheel on due to room on the adapter between the new studs and the recesses for the nuts to hold the adapter to the hub.Most companys want to work with atleast 20mm think adapters Edited September 18, 2012 by zebedee Quote
