grimr3ap3r_ Posted October 10, 2012 Share Posted October 10, 2012 Removed circlip,Tapped compressor housing so it's came off,Do I removed the locating pin them simply put it back together and put the circlip back in?Thanks Liam Quote Link to post Share on other sites
turbo Grant Posted October 10, 2012 Share Posted October 10, 2012 (edited) I left the pin out when I done mine. Just simply release the pressure in the c-clip and spin it wound. Never moved once o rotated mine. Presume you are external gatted or do you have a bracket for the actuator Edited October 10, 2012 by turbo Grant Quote Link to post Share on other sites
grimr3ap3r_ Posted October 10, 2012 Author Share Posted October 10, 2012 Externally gated mate someone said I need to remove the pin but I'll just twist it thenThanks for your helpLiam Quote Link to post Share on other sites
turbo Grant Posted October 10, 2012 Share Posted October 10, 2012 Yeah you will need to remove the pin. Was a few years since I done my ct9 Quote Link to post Share on other sites
grimr3ap3r_ Posted October 10, 2012 Author Share Posted October 10, 2012 I ain't removed the pin just hit it and spun it will that be ok? Quote Link to post Share on other sites
turbo Grant Posted October 10, 2012 Share Posted October 10, 2012 As long as its feels tight still. Should be ok. Only one way to find out. See what it drives like. From memory it's only a tiny pin so it would have just snapped. Quote Link to post Share on other sites
grimr3ap3r_ Posted October 10, 2012 Author Share Posted October 10, 2012 It won't be inside the compressor housing will it? I saw it bend but didn't see it break off And it feels tighter then a Somalians bum hole Quote Link to post Share on other sites
turbo Grant Posted October 10, 2012 Share Posted October 10, 2012 It will be fine then. It can't get past the seal Quote Link to post Share on other sites
grimr3ap3r_ Posted October 10, 2012 Author Share Posted October 10, 2012 Ok cool just looked and I can still see it through the lil gap anyway so musts broke a spin with the compressor housing Quote Link to post Share on other sites
