Also pedal box and clutch master cylinder. Lines down to slave cylinder, Flywheel and clutch and the flywheel to crank bolts as they are shorter on auto's
. You can use your auto ecu. You will need to jump the parking switch tho as autos need to be in park to start!
Im using an auto ecu on my 4age swap and this is all i did. I've been running it 18months and its never missed a beat!
