Recently brought a Glanza, and I am just getting round to sorting the usual little bits and bobs, the center console (heating controls) have two bulbs which I have tested, one was faulty other was working fine, but I get no light what so ever and have no power to the lighting circuit I think. I did test it with a working set of bulbs to no avail. What could be the cause of this? I don't think it was a fuse, as we did visually check them the day after buying it.
Thanks!
  • 2 weeks later...
I had this and turned out to be shitty wiring from the ignition :s don't know if its worth you giving it a wiggle :p worked for me :)
Remember how old these cars are folks! How would u look after behind under a dashboard for nearly 20years :D
I'd look pretty damn oily if id been hiding in mine for that long ha :p
On my GT it was the wiring from the right hand side at the back under the bonnet to inside the dash. Might not be the same on glanzas? Not sure.
I'll take a photo tonight to show you if you cant find it? Duno how to explain really, I suck at electrics :p
Edited by melon
