Is there only supposed to be ONE plug on a starlet Fet turbo timer? Its just i seen images on google n theyv all got 2....anyone shed some light?
ok, so the wee white plug is situated approx 8inches from ignition plug and im presuming its for the turbo timer as its the ONLY female plug in the whole loom (unless I've missed 1) that fits the timers male connector! have a look n tell me what u guys think.in the last pic u see its plugged in perfectly6894F777-orig.jpgF7CFC5D0-orig.jpg!474B8E59-orig.jpg
Edited by PaulStarletSR
Aye a jumped in it this mornin and found 1 single plug,there are no other plugs bar 1 and it plugs straight in with no fuss! :-) hope this is it lol
ma uncle said we should get everythin ready for a switch on and fire it up with the dash off to see if it smokes,and if it works with the engine:-)
Aye at might be it then mate. Aye ats a plan we'll do that. Ul need to get it up on axle stands to get the exahust on n done up. After at its getting all the turbo on. then get your rad n fan plumbed in then check and fill up fluids ie, oil, gearbox oil, powersteerin fuild, brake fluid, fill the fad up with water/coolent, plugs in and then she'll be ready to fire. still a bit to do but shouldnt take long mate. U got oil n at for it? :D
No got the oil yet but can when were ready,everythins plug n play,rad has plug and while cars jackd up need to drill the eye bolt hole for passenger harness.u got a 10mm drill bit mate?wires and visor out the glanza 2? :-))
You need a harness for it Paul that the fag lighter plug you have it plugged into :p
Like this:
Edited by Simon
^^^simons ryt mate need a harness. u need to take the ignition plug out n plug it into one side of the harness then plug the other side into where u took the plug out. Then the turbo timer plugs in to the 3 wee plug. :)
