Hi guys lookin for a little bit of help on boost pipes im looking to do away with the standard metal pipes and hopfully do a hi/lo boost bypass at the same time (if its the right senser) but a i cant remember were the pipes went. :/ could any one point me in the right direction?? Heres a pic to make it easyer. :)
any help would be grait. :D
Am i right with this pic? is this were u bypass the hi/lo boost and the red one comes from the inlet but dont know were it goes to?!!! :/
the red one would go to your dump valve or recirc valve and the other 2 are high and low boost if im right mate :)
look under the pipes neer the white arrow and thers a solenoid there that the 2 pipes go 2 just loop that and job done :thumbsup:
im
prety sure anyway
(ive done it on my glanza but its a gt boost sensor so should be possible)
Edited by PhilGT93
Thats what i thought just needed someone to confirm it lol Klkl phil that helps alot. yeh it is a solenoid with two outputs for pipes. al just run a hose from the dump valve straight to the inlet & loop the solenoid. cheers for the help buddy. :-D
Take it u have a glanza? At the front on top of your abs pump u will See to hoses connected to solonoids 1 goes to the plastic air intake pipe above turbo other goes on to that metal pipe on engine near your power steering take the hoses off bridge the two solonoids together with 1 hose then bridge th other two for Hi boost mod
