5T4R7ET N/A Posted November 2, 2012 Posted November 2, 2012 (edited) ^^ as above, thats a pretty good explanation of what is reqiured for PCV valve.the breather on the right that has the PCV valve is completly different in terms of ventilation to one on the left.if you have oil around the PCV valve (breather on right) its most likely the bung that holds the valve is worn and letting tiny amounts of oil through. nothing to worry about Edited November 2, 2012 by 5T4R7ET N/A Quote
Danza V Posted February 15, 2013 Posted February 15, 2013 No good just fitting a pipe from the can to the PVC and one from breather as th PVC needs vcumm to open trisks is good way.. Or you can jut get rid of your pcv altogether and use a race type rocker cover. Quote
