Need some help with shock absorbers
Hi guys I have just bought some check absorbers and was wondering if they are doing what they are supposed to..
The front 2 are TRD, I think they are oil filled. Once you compress them, should they return on their own because they don't....
are they just meant to absorb the shock rather than return, I'm, hoping they aren't fukd
The rears are KYB gas-a-just which do return once compressed.
this happens alot...
they look nicey nicey
sold as working etc with a nice premium due to them being jdmzzzz
but as you found out instead of just throwing them on...when u push them down they dont return/resist force (as all working shock absorbers do) so they are duff the rears are fine if they return
Its only street shock absorbers that return to its starting point. Race specs, do not return.
Oil ones is must likely open in the top where the piston enters the damper. Gas filled, are closed so the gas can't escape...
Just read this on Passion Ford....
It appears oil filled do not rebound on their own
  Quote
It is a misconception that a gas shock works on gas alone, where as an oil (normal) shock works on oil. All conventional automotive shocks work by forcing oil through a determined set of holes, but a gas shock will use compressed gas to keep the oil under pressure.
This is done largely to minimise aeration or "foaming" of the oil which would reduce the effectiveness of the shock as air passes through the valves rather than fluid. The gas also helps to dissipate heat which keeps the oil cooler and maintains the viscosity and therefore the shock "rate". Gas shocks are ideally suited to long travel applications like rallying and off road. *
There are many types of gas shock, twin-tube, mono-tube and remote canister combinations for super heavy-duty use like rallying and off-road racing. Most of the economical gas shocks are of a twin tube construction (low-pressure) where as most performance or race gas shocks use a mono-tube (high-pressure) system. There is no such thing as an ideal system, it really depends on the application as mono-tubes may have advantages in some respect but the high-pressure gas can act as a spring complicating the suspension design process.
The main disadvantage of a gas-pressurised shock is cost which leads to a very simple rule of thumb to help avoid confusion. If faced with a choice of gas or oil for the same price, it's unlikely that the real working part of the gas shock is of the same standard and level of sophistication as the oil. You get what you pay for!!!!
With regard to shock pistons rebounding when pushed in, this will not happen on oil based shocks, but on gas pressurised shocks if the rod is pressed down relatively quickly it can rebound due to the higher residual pressure beneath the piston itself.
Remember also a shock absorber is actually termed a damper. This means its primary role is to damp out spring oscillations that would otherwise result in some very nasty bouncy effects every time you drove over an uneven surface!!! icon_mrgreen.gif
Edited by Haresign
