Hey guys and gals
recently put a forged engine in my glanza replica. Got the engine and wiring out of a ep91 which got it from a ep82 gt.
Pretty much as soon as i start the car the temperature guage goes all the way up :/ going crazy..went over wiring a few times
for the GT engines does the signal for temperature go to the ECU then to the dash? cause i think there is a temperature port on the ECU
if anyone can help me it will be good
thanks
You've put the spade connector on the wrong sensor by the sound of it, easy fix.
Cheers
Idrees
ID-Workz
x2, theres one connection on the thermo housing which goes straight to the dash, tiny spade connector, single wire.
thanks for all the help guys :)
also forgot to mention i got a glanza dash..so from the thermo housing run it straight through to the dash with a single wire?
was looking at the ECU and there is 2 cables that might lead to the dash also
sorry to double post.
wired it straight through the thermo housing and through the ecu
removed that sensor put in another one i had and same thing it shoot straight up
wondering if there we need some resistance somewhere maybe a relay :/
