Hi all,
Im just wondering if my N/A gearbox will go onto a 4EFTE without any problems or is it weaker than the turbo one????
will i also be able to use my own drive shafts.
cheers for any help.
it has been done with the n/a gearbox, but if your gonna have the engine out, your gonna need to change the clutch for one that can take the power, so you've gotta have the gearbox off anywho. best to change it to be on the safe side. i cant see the shafts being much different tho.
