Dean-Dak Posted November 8, 2012 Posted November 8, 2012 In having issues removing my driveshaft from the gearbox on my 96 Glanza vI tried just pulling the driveshaft and it split the joint inside the bootI can tell from my new shaft it has a little ring around the end, so it's obviously that causing the issueAny help would be appreciated with my issue Quote
Taggy Posted November 8, 2012 Posted November 8, 2012 If you have access grab it wth both hands and yank it out, or use a bar against the grooves on it and wedge it out, they can be a bit stiff but keep at it, it will come out Quote
mattyD Posted November 8, 2012 Posted November 8, 2012 As said, ideally you need to tap a bit with a hammer and chisel to knock the set ring out of place then it will come off nice and easy I work with the buggers every day! Bit of a bitch if you pop the cv joint so be careful ;) As said, ideally you need to tap a bit with a hammer and chisel to knock the set ring out of place then it will come off nice and easy I work with the buggers every day! Bit of a bitch if you pop the cv joint so be careful when putting the new one in ;) Quote
