Is there any difference between a glanza tank and a n/a starlet tank? I need a new tank for a 97 n/a. Will a Glanza one fit? And will I be able to use the standard pump with the glanza tank?
Cheers,
Phil
  • 4 weeks later...
It depends on the year of the car, they are not all the same. Take your rear seats out and remove the silver fuel pump cover, check if your fuel pump is the same shape as the Glanza one you're looking to buy.
The later EP91s have a different tank, both UK spec and Glanza. We have both types of tanks in stock if you are stuck for one anyway.
