Starbo Posted June 27, 2007 Posted June 27, 2007 Not knowing anything about the starbo's wheel fitment would these fit?ET 45 4X100 PCD 6.5J X 16 Also if they do is it a good fitment? Quote
StarletRick Posted June 27, 2007 Posted June 27, 2007 they'd poke out a bit but yeah theyd fit. Quote
keirz Posted June 27, 2007 Posted June 27, 2007 the wheels should still sit inside the arches nicely with out sticking out.you may be ok to be honest. i used to run 45 offset 16s which were 7"wide and only had minor scrubbing with passengers at standard ride hight and quite alot of scrubbing dropped 40mm with passengers. but thats with a 7" wide.with yours being 6.5" you may be ok. if its gonna catch it will be on the drivers side rear. an adjustable panhard rod should sort this if your car is lowered as it will pull the axle back to center. Quote
Idrees Posted June 27, 2007 Posted June 27, 2007 I've got temporary rims with ET45 offset and they rub badly on the inner front arches when turning. Quote
