ali_legend Posted November 19, 2012 Posted November 19, 2012 Hi guys as above I bought a blitz voice guided turbo timer off a guy on here. Anyway the TT was sold with a wiring harness for an ep82. Plugged the harness in and then earthed it and sent a live to it.Now the problem is.. When turning the car on orIgnition the TT turns on. I can set a time and hear the voice etc.. Now when I turn the key to turn the car off the engine goes off and the TT goes off. Any ideas? Quote
A L 3 X Posted November 19, 2012 Posted November 19, 2012 I think one of your ignition wires is wrong way round, try swapping the blue and green i think it is? Quote
dai_starletN/A Posted November 19, 2012 Posted November 19, 2012 i got the same turbo timer ill get a pic tomorrow of how i got it wired casue i had to buy two other harnesses to get it to work Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 I think one of your ignition wires is wrong way round, try swapping the blue and green i think it is?The harness plugged into the ignition so I shouldn't have to take wires out of the harness surely? Or do I There was a purple wire and an orange one for earth and another one that I had no clue about loli got the same turbo timer ill get a pic tomorrow of how i got it wired casue i had to buy two other harnesses to get it to workNo way?! Did you have a harness? Cba for that!! Quote
A L 3 X Posted November 19, 2012 Posted November 19, 2012 The harness plugged into the ignition so I shouldn't have to take wires out of the harness surely? Or do I There was a purple wire and an orange one for earth and another one that I had no clue about lolMaybe not then mate, I tried it on another car wiring in by hand, and got the two wrong and it used to do that, but with a harness it should be plug and play Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 Maybe not then mate, I tried it on another car wiring in by hand, and got the two wrong and it used to do that, but with a harness it should be plug and playYh exactly what I was thinking. Quote
dai_starletN/A Posted November 19, 2012 Posted November 19, 2012 The harness plugged into the ignition so I shouldn't have to take wires out of the harness surely? Or do I There was a purple wire and an orange one for earth and another one that I had no clue about lolNo way?! Did you have a harness? Cba for that!!The harness plugged into the ignition so I shouldn't have to take wires out of the harness surely? Or do I There was a purple wire and an orange one for earth and another one that I had no clue about lolNo way?! Did you have a harness? Cba for that!!just the turbo timer i had to buy these />http://www.ebay.co.uk/itm/BLITZ-TURBO-TIMER-HARNESS-TOYOTA-STARLET-TURBO-EP82-/270820988532?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0e305674/>http://www.ebay.co.uk/itm/BLITZ-TURBO-TIMER-ACCESSORY-HARNESS-/271051093821?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1be7773d Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 just the turbo timer i had to buy these />http://www.ebay.co.uk/itm/BLITZ-TURBO-TIMER-HARNESS-TOYOTA-STARLET-TURBO-EP82-/270820988532?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0e305674/>http://www.ebay.co.uk/itm/BLITZ-TURBO-TIMER-ACCESSORY-HARNESS-/271051093821?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1be7773d Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 just the turbo timer i had to buy these />http://www.ebay.co.uk/itm/BLITZ-TURBO-TIMER-HARNESS-TOYOTA-STARLET-TURBO-EP82-/270820988532?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0e305674/>http://www.ebay.co.uk/itm/BLITZ-TURBO-TIMER-ACCESSORY-HARNESS-/271051093821?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1be7773dPretty sure I've got both of them mate. As the guy said the full ep82 harness is there. Did you just plug and play then? Obviously earthed and wired into a live but that's it? Didn't need to wire into handbrake or anything? Did you have no spare wires then that are unused? Quote
dai_starletN/A Posted November 19, 2012 Posted November 19, 2012 Pretty sure I've got both of them mate. As the guy said the full ep82 harness is there. Did you just plug and play then? Obviously earthed and wired into a live but that's it? Didn't need to wire into handbrake or anything? Did you have no spare wires then that are unused?it was pretty much plug n play but i had to cut three wires on the harness so two are not in use one one is i'll get a pic or a vid to explain it Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 it was pretty much plug n play but i had to cut three wires on the harness so two are not in use one one is i'll get a pic or a vid to explain itIf you could please bro. Hope it's not no confusing shizzle! Lol Quote
dai_starletN/A Posted November 19, 2012 Posted November 19, 2012 If you could please bro. Hope it's not no confusing shizzle! Lolits so easy seriously you would kick yourself lol Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 its so easy seriously you would kick yourself lolPhew!! You got a pik of your TT? Did you wre an earth and live obviously but did you wire to handbrake? Quote
A L 3 X Posted November 19, 2012 Posted November 19, 2012 In fact, if you don't use the handbrake feature do you not need to ground that wire out? Im sure it works as though the handbrakes grounded when on, so if the wire aint connected, no ground?I would advise wiring to handbrake sooner rather than later though. Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 In fact, if you don't use the handbrake feature do you not need to ground that wire out? Im sure it works as though the handbrakes grounded when on, so if the wire aint connected, no ground?I would advise wiring to handbrake sooner rather than later though.Yh exactly makes sense! Only thing is I have no idea which wire is needed to wire to the handbrake or ground it lol Quote
dai_starletN/A Posted November 19, 2012 Posted November 19, 2012 i'll get a pic tomorrow it will show how i did it and no i didnt wire it in to the hand brake Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 i'll get a pic tomorrow it will show how i did it and no i didnt wire it in to the hand brakeNice one bro. Colour of wires would be wicked too Quote
dai_starletN/A Posted November 19, 2012 Posted November 19, 2012 Nice one bro. Colour of wires would be wicked too i need to take the lower dash cover off anyway cause i forgot to plug the speaker back in i just got lazy to do it since i put the TT in the car in september lol Quote
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 i need to take the lower dash cover off anyway cause i forgot to plug the speaker back in i just got lazy to do it since i put the TT in the car in september lolHaha win win for me Quote
