1990timeismoney Posted November 25, 2012 Share Posted November 25, 2012 hi ive run a fault code check and its coming up with 52 how bad is this what is the cause and how can i fix it.any help appreciated.thanks Quote Link to post Share on other sites
StarletMad Posted November 25, 2012 Share Posted November 25, 2012 Have you tried replacing it? Quote Link to post Share on other sites
1990timeismoney Posted November 25, 2012 Author Share Posted November 25, 2012 Have you tried replacing it?im not sure where it is on the car its was fine i drove it to garage and on way back it came on will it still be ok to drive Quote Link to post Share on other sites
StarletMad Posted November 25, 2012 Share Posted November 25, 2012 http://www.camskill.co.uk/m19b663s1296p13038/_TOYOTA_OE_GENUINE_PARTS_-_Knock_Sensor_-_Toyota_Starlet_Turbo_EP82_and_EP91Ask id-workz hes your man for cheap genuine parts Quote Link to post Share on other sites
1990timeismoney Posted November 25, 2012 Author Share Posted November 25, 2012 http://www.camskill....o_EP82_and_EP91Ask id-workz hes your man for cheap genuine partsok thanks ill send him a message.will it still be ok to drive.how do you reset the codes as i cant find the efi fuse in engine as all the writing has been removed,.thanks Quote Link to post Share on other sites
StarletMad Posted November 25, 2012 Share Posted November 25, 2012 Have a quick search on tgtt theres a great write up on there mate Quote Link to post Share on other sites
StarletMad Posted November 25, 2012 Share Posted November 25, 2012 Found ithttp://www.toyotagtturbo.com/forums/showthread.php?71074-EFI-self-diagnosis-system-* Quote Link to post Share on other sites
1990timeismoney Posted November 25, 2012 Author Share Posted November 25, 2012 thanks that's a great help Quote Link to post Share on other sites
Idrees Posted November 25, 2012 Share Posted November 25, 2012 The knock sensor only has one wire on the plug and I've seen them get damaged, so double check that the wire doesn't have any nicks or splits in it. The sensor is under the inlet manifold on the right side (when looking from the front of the car) at the back of the engine. If you do need a new one then drop me a PM (thanks Jono). Quote Link to post Share on other sites
