HELP Boost issues, checked all the usuals
my car wont boost above 0 bar, ive ditched the greddy boost controller and all the tee offs to isolate that and its all set back to standard and still wont boost beyond 0 bar, i can see the wastegate is working and i cant see any visible leaks, any help would be much appreciated !
thanks
Check the compressor blades are still in one piece! or as said above make sure its spinning!
Also if you have a front mount intercooler check the pipes i've known a few people have holes in the alloy pipes off them rubbing against things!
