HA, you have built my confidence up a bit mate :p
so what is the actual point of a 'higher flow' fuel rail if its the injectors that control the fueling? just a gimmick then no?
its all about the bling bling :p
what injectors are you running dude?
Ive got 550cc injectors running 3 bar fuel pressure
Jeez fuck me thats some going!
The idea of a larger fuel rail is to stop it from running dry. If you've only got a small rail, then the injectors will take all the fuel and the rail will run dry, if you have a larger rail theres more fuel in the rail, so if the injectors take x amount theres still fuel left over, hence they are "larger volume"
Edited by AdamB
