steve-gers Posted December 1, 2012 Share Posted December 1, 2012 What is the sensor that sits in behind the manifold near the right had side of the engine. It's near to the slave cylinder on the gearbox it's a kind of bar with a ball on the end and the plug just pushes onto it. Need to know as I broke the connector off it when removing it and need to figure out a way of fixing it. Quote Link to post Share on other sites
starletburkie Posted December 1, 2012 Share Posted December 1, 2012 oil pressure sensor Quote Link to post Share on other sites
steve-gers Posted December 1, 2012 Author Share Posted December 1, 2012 The one for the light on the dash? Quote Link to post Share on other sites
starletburkie Posted December 1, 2012 Share Posted December 1, 2012 yea Quote Link to post Share on other sites
steve-gers Posted December 1, 2012 Author Share Posted December 1, 2012 Ok thanks very much. This has never worked since I bought the car so not a big issue although I may aswell repair it now the engine is out. I was thinking of screwing a big bit of connector block over the sensor then cutting the plug off the connector, stripping the wire and putting it in the other side of the connector block as a fix. Bit pikey but only thing I can think of. Quote Link to post Share on other sites
Simon Posted December 1, 2012 Share Posted December 1, 2012 http://www.camskill.co.uk/m19b0s1296p4237/_TOYOTA_STARLET_TURBO_%28EP82_EP91%29_-_SERVICING_PARTS_TUNING_SPARES_and_SERVICE_ACCESSORIES_-_Oil_Pressure_Switch_-_All_Starlet_EP82_EP91_Turbo_Models6 quid for a new one Quote Link to post Share on other sites
steve-gers Posted December 1, 2012 Author Share Posted December 1, 2012 The sensor is fine it's the connector that is broke Quote Link to post Share on other sites
Simon Posted December 1, 2012 Share Posted December 1, 2012 With a bit of work a standard female spade terminal will fit and stay on there Quote Link to post Share on other sites
steve-gers Posted December 1, 2012 Author Share Posted December 1, 2012 will give that a bash Quote Link to post Share on other sites
