Bought some of these and seem ok, they got put on. Now after a while ABS light has come on. Diagnostic showing that there is no signal.
Is there different ones for different years? I would have thought a glanza drivershaft would be the same whatever the year.
My car is an s reg, got shafts off that matt black breaker. Still need to drive it to see if it has solved my vibration issue or not.
Check to make sure there isnt any crap stook on the sensor that plugs into the hub!
Cheers buddy, AFAIK this has been done :s. Is there different types, can't understand why it would give me jip. Stupid cars
See when i changed my CV joints for aftermarket ones on my old V the ABS light come on and i couldnt get it off!
Im not sure if it was because the teeth on the aftermarket CV joint where to small/ not tall though so the sensor wasnt picking it up as it works off a magent! But i will never now because i've sold it haha
Yay sorted my vibration.
Abs light is now on though, thinks the abs ring is smaller so the sensor fires a code up saying no signal.
Can you just swap abs rings round or not?
