Chris Green Posted December 23, 2012 Posted December 23, 2012 (edited) Hi guys,I have just finished the engine swap from a 4e-fe to a 5e-fhe. I have double checked every thing and it won't turn over. I haven't connected the HT leads yet as I wanted to check it turned over without starting itWhen I turn the key all I get is a humming noise. Does anyone have a clue as to what this could be?Cheers Chris Edited December 23, 2012 by chrisgreen1993 Quote
Azz Posted December 23, 2012 Posted December 23, 2012 Have you tried swapping wires on the starter? Sound like something with the starter if its just huming Quote
Chris Green Posted December 23, 2012 Author Posted December 23, 2012 I'll give that a go now.Cheers Quote
morgey Posted December 23, 2012 Posted December 23, 2012 Humming sounds like fuel pump. Check all your earths on your engine etc Quote
Chris Green Posted December 23, 2012 Author Posted December 23, 2012 Problem sorted, dodgy wire to the started motor. Cheers guys. Quote
