Ep91Ben Posted December 28, 2012 Posted December 28, 2012 Has any body used the turbo smart fuel cut defender? Or what would people recommend to use ? If they had to use one ? Only be for abit till I can get some emanage Help appreciated Quote
StuDoc 72 Posted December 28, 2012 Posted December 28, 2012 Why not just run low boost until you get emanage? Save yourself money and more than likely an engine. FCD's are an accident waiting to happen save up do it right and be patient.Good things come...... Quote
Jamie_VF22 Posted December 28, 2012 Posted December 28, 2012 ^^^^ As above just save your money and it right pal Quote
Liam_D Posted December 28, 2012 Posted December 28, 2012 As what everyone else has said really not a fan of the way FCDs work. Turn the boost down until you can afford an external set up or some proper management. Quote
Ep91Ben Posted December 28, 2012 Author Posted December 28, 2012 I'm getting an external ct9 kit and yeah was going to run 0.7 bar what spring will I need in my waste gate? Think that's what I'm going to do until I save up a few more penny's to get emb Quote
Ep91Ben Posted December 28, 2012 Author Posted December 28, 2012 Also was out the other night going pretty quick in 4 th and boost gauge went up to 14 psi and didn't hit fuel cut ? Does any one know why this is ? Haven't got a fuel cut defender ether ? :s Quote
Matt1878 Posted December 28, 2012 Posted December 28, 2012 Also was out the other night going pretty quick in 4 th and boost gauge went up to 14 psi and didn't hit fuel cut ? Does any one know why this is ? Haven't got a fuel cut defender ether ? :sStandard ECU? Could be a faulty boost gauge?Matt Quote
Ep91Ben Posted December 28, 2012 Author Posted December 28, 2012 Just put a new boost gauge in other one did the same and yeah as far as I can see the ecu is standard Quote
steve-gers Posted December 28, 2012 Posted December 28, 2012 (edited) I have an HKS FCD just removed on 21st to fit emanage, £50 delivered if you want it. Edited December 29, 2012 by steve-gers Quote
Weyro Posted December 29, 2012 Posted December 29, 2012 Ive been running an HKS FCD and rrFPR with a td04 at 1bar for over 6 months, not saying yours wont explode but mine hasnt lol Quote
