Glanza AuA Posted December 30, 2012 Posted December 30, 2012 hi guys just got this evc4 EBC but i cant seem to understand the diagram could someone help me out as where the vacuum hoses needs to go ?im td04l external wastegatehere is the diagram : Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 isn't this the same pic i just posted ?? where does left middle and right hoses from solenoid go ??sorry as i don't understand the diagram Quote
morgey Posted December 30, 2012 Posted December 30, 2012 From what i can gather by looking at them picsCenter line to wastegate Smallest of the 3 to your inlet manifoldOther side the larger outside one to somewhere on your intercooler piping (after turbo before the throttle body)The 4th port on the other side would be left open to atmosphere Quote
morgey Posted December 30, 2012 Posted December 30, 2012 That 2nd pic is different as the wastegate has 2 ports on it :s Quote
Weyro Posted December 30, 2012 Posted December 30, 2012 Yea the second pic is for external wastegates, whereas the one you posted is for internal gates.What type of wastegate do you have, what make? Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 yep just noticed that for dual Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 so the larger one goes to my int piping but where ?? to my BOV ?? Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 i have an external wastegate dont know the brand its just uprated like the HKS one running td04l Quote
Weyro Posted December 30, 2012 Posted December 30, 2012 the stepper motor looks different but its the same idea Quote
morgey Posted December 30, 2012 Posted December 30, 2012 Have you not got any other nipples on the int piping that you could feed it into? Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 the stepper motor looks different but its the same ideavery helpful thanks a lot Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 Have you not got any other nipples on the int piping that you could feed it into?no i dont does this really need to go to the int piping ?? Quote
Weyro Posted December 30, 2012 Posted December 30, 2012 the small one needs to be connected to an outlet on the Inlet manifold. Quote
morgey Posted December 30, 2012 Posted December 30, 2012 Well either off of the turbo or the int piping.I would say replace that red int piping with the black hose going to it (pictured ^^) with your inlet manifold and go with thatAlso yours will differ depending if your wastegate is single or dual lined? Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 got it!! also noticed on my actuator does not have 2 nipples just 1 that goes to the turbo ?? Quote
morgey Posted December 30, 2012 Posted December 30, 2012 (edited) Right one off turbo into larger outside feed on ebc.Center one to waste gateSmaller outside feed to inlet manifoldThat should be it Edited December 30, 2012 by morgey Quote
Weyro Posted December 30, 2012 Posted December 30, 2012 (edited) ok yours will look like this then: Edited December 30, 2012 by Weyro Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 wooow you guys are legend Weyro & morgey really appreciate this UKSO FTW : thanks guys Quote
Weyro Posted December 30, 2012 Posted December 30, 2012 no problem, if you need a hand getting the settings right on the control unit just let me know Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 (edited) no problem, if you need a hand getting the settings right on the control unit just let me knowcoolz will give an update and get back 2 you once installed Edited December 30, 2012 by Glanza AuA Quote
akyakapotter Posted December 30, 2012 Posted December 30, 2012 If you get stuck pipe up I have one on EWG Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 If you get stuck pipe up I have one on EWG hopefully wont happen Quote
Glanza AuA Posted December 30, 2012 Author Posted December 30, 2012 (edited) got it installed guys thanks a lot manage to read the setup procedure, had to decrease my actuator and make the EBC the higher one:) there's even an self learning mode but have to do that on a long road, but for now everything is running spot onthanks again guys Edited December 30, 2012 by Glanza AuA Quote
