Gainzy Posted January 1, 2013 Posted January 1, 2013 Having a good look tomorrow I suspect the heater matrix has given up or some sort of rubber seal...my heater still works just if the matrix has gone is it pretty easy to fix etc? Quote
morgey Posted January 1, 2013 Posted January 1, 2013 Under the floor is a rubber bung mine have fallen out so the carpet gets wet and my car steams up now. I doubt the drivers footwell would get wet from the heater matrix as its the other side of the tunnel Quote
Gainzy Posted January 1, 2013 Author Posted January 1, 2013 Cool hope it is that! Is there another one on the passenger side aswell? Quote
Gainzy Posted January 1, 2013 Author Posted January 1, 2013 Cheers!! i its only wet in those two same places can ot be sorted from inside? Or is it new rubber underneath job? Quote
morgey Posted January 1, 2013 Posted January 1, 2013 Gota be done from underneath unless you have no carpet, you could prob see the holes or bungs even with it on the floor if not jack it up Quote
morgey Posted January 1, 2013 Posted January 1, 2013 Failing the bungs being missing. The bungs in the door area for the electrics might have popped off letting water in around that area Quote
Gainzy Posted January 1, 2013 Author Posted January 1, 2013 Al pull the carpet back n dry it up n go from there al have sum silicon somewhere if needs be thanks matey Quote
