leemillin Posted January 2, 2013 Posted January 2, 2013 (edited) My starlet will need a timing belt very soon. what else do you need to change when u do a timing belt? Edited January 2, 2013 by leemillin Quote
td04 turbo Posted January 2, 2013 Posted January 2, 2013 Worth buying the timing belt kit with idle pullys tensioner ect also pays to change water pump while your there Quote
leemillin Posted January 2, 2013 Author Posted January 2, 2013 what does the kit come with? i've been told i can get it all done with water pump n cambelt £230. is that good or not? Quote
Idrees Posted January 2, 2013 Posted January 2, 2013 The timing belt kit comes with idler and tensioner. It's always a good idea to change the water pump at the same time. Both parts are £75.60 delivered on our website if you need them. Quote
leemillin Posted January 2, 2013 Author Posted January 2, 2013 so i dont need 2 change anything else? Quote
Sefton-EP91 Posted January 2, 2013 Posted January 2, 2013 (edited) Water pump and again go for a kit I got mine from Idrees. No problems at all Edited January 2, 2013 by Sefton-EP91 Quote
leemillin Posted January 3, 2013 Author Posted January 3, 2013 is it worth me gettin my auxiliary belt done at the sametime when i get the cambelt n water pump done? Quote
Neo Gold Posted January 3, 2013 Posted January 3, 2013 is it worth me gettin my auxiliary belt done at the sametime when i get the cambelt n water pump done?Yes of course, there only a couple of quid!!.. Quote
Sefton-EP91 Posted January 6, 2013 Posted January 6, 2013 You could get the aux belts done but it all depends what your budgets like, from Idrees there really cheap but real good quality. I done my thermostat, water pump, full coolant flush. Both auxiliary belts and the cambelt and tensioner/rollers. Whilst its off, if you got the money replace it Quote
