so got myself some new wheels, went for a little trial fit and they dont sit flush against the hub. the hub has a little lip on it that the centre holes of the old wheels slid over but the new ones centre hole is slightly smaller and bevelled so doesnt go on.
anyone got a solution on how to sort it? will i have to grind some of the centre hole so its larger to slide over?
Pinske
i thought about spacers but then ill have to get longer studs to have enough thread for the nuts :/
sweet, ill get them machined then! thanks :)
The centre bore of the wheels you have brough is wrong (too small)
You have checked they don't have any spigot rings fitted that you could remove?
If not the only option you have is to get them machined correctly to fit your hubs this should be done by a machine shop as you need the wheel to centre on the hub to take the load away from the studs. Not doing this could cause a wheel in balance causing steering wheel wobble and in the worst case the studs could snap.
Personally if possible i would go bigger then fit a spigot ring so that you can open up the market when you come to sell toyota has one of the smallest c/b's
