The central locking on my 98 SR only works if you do it from the pass door and the interior button only works for the drivers door. It is done on a barrel type manual lock, not with a remote fob. Has anyone had this problem before or can anyone shed some light? Cheers
my drivers door and boot decided to stop being usable with a key but can still use it in the passengers door? the remote still does the central though lol
i would hazard a guess at the trigger wire on the open pass door has got a break in it somewhere
If u push the door lock button on the driver door beside the window switch u can here if a relay or motor arnt working. Also the locks dry up over time, especially the boot. Repeated sprays of wd40 or other oil with a straw fitting on the nozzle frees them up. 1 or 2 squirts them leave it a day. Badly siezed bootlocks can be soaked in 3in1 oil. Watch for bad earths around the door sills near where the door loom plugs in. the remote central locking and alarm loom on a paseo would be.handy put in a Sr
