Socks Posted January 8, 2013 Posted January 8, 2013 Auto Throttle Position Sensor Electric Connector (4 pin)Connector with some wire off the end to make into a loom...RegardsMatt
turbo Grant Posted January 8, 2013 Posted January 8, 2013 The paseo runs a 4 wire tps might be the same plug
Socks Posted January 8, 2013 Author Posted January 8, 2013 The paseo runs a 4 wire tps might be the same plugInteresting! Want to get me a pic of your connector babe x
turbo Grant Posted January 8, 2013 Posted January 8, 2013 Only has 3 wires connected so you would have to pop another terminal in if using 4 wires
Idrees Posted January 12, 2013 Posted January 12, 2013 I can supply the plug off a Paseo if it's definitely the one you need Matt.
Socks Posted January 12, 2013 Author Posted January 12, 2013 Let me get a snap of the auto tps I have... as long as pin and clip work... ican remove any guiding slots
