I had machined down 256mm discs on my uk spec to 238mm and this meant the inside pad had about 5mm floating, the floating bit broke off eventually but never caused any other damage.
Edited by morgey
no bother thanks. think i'll go ahead with it then
  • 4 weeks later...
Its a lot of hassle getting the st205 calipers to fit properly on the other celicas, even of the same year.
Tends to work out not worth the hassle and cheaper to just buy a BBK
so id be supprised if they fit on a starlet to be honest :)
