Just recently built a 5efhe +T but am having issues finding a gear box have got a mate with a ae 101 LSD 5speed but heard they don't fit and the ae111 LSDs are hard to come by wat would be your guys suggestions thanks lincoln.
The ae101 5speed boxes are the same as ae111 boxes just with different gear ratio's.
If you use the bell housing from the 5efhe you should be able to use almost any gearbox that any 4e/5e/4a or 7a series engine came with as they all use 'C' series gearboxes (apart from 4agZe's i have heard they are different maybe an 'S' series)
The only thing you would need to check is that your driveshafts fit into the gearbox correctly.
Yea I think the drive shafts was the reason why it didn't work but will try fit anyway thanks for your guys help will post up pics and that over next couple weeks also done a tube front to mount glanza front on
