Gearbox end housing - small crack repair ?
Just spent a fortune having a new clutch and gearbox and driveshafts put in only for the guy to spot a crack in the 5th gear housing (passenger side end of the box). Its leaking a little bit of oil.. Are there any ways to repair this without having the box taken off AGAIN :( .
Cheers.
Thanks mate.. Thinkin there might be another leak on where the main gearbox is bolted to the clutch housing (if you get what i mean, not the part bolted to the engine but the part bolted to that part lol)
I have shite all luck :( .. Need to get under it and have a look but what options do i have if that seal is fooked ? Last resort being, getting a garage to take the gearbox off AGAIN and get it apart and re-sealed :(
Thanks so far guys.
