Cant you use either the rear seat mount or where the original seat belt buckle mounts on the side of the seat?
I could but that would mean cutting and drilling the recaro seat. I didnt want to do that but it looks like its going that way.
id use the origonal seat belt buckle as your fixing point bud. alsway use seatbelt oem poits where possable.
same suggestion as above but I wanted to leave the recaro seat intact and use the seatbelt whenever i wanted to, aswell as having the harness
they are bolted on but the bolt itself is welded to the seat (from factory) so a threaded end sticks out and the standard buckle is bolted to this. I want to keep both harness and standard belt
