looking oil lines to suit a TD04L turbo or even if i could make them any help appreciated :)
also lookin an EBC cheapish sori but the funds is running low an still trying to get this td04 up an running
I almost had one made by a local place a few weeks ago, the issues that were faced were:-
Would the ptfe lining take the oil temp + the manifold and turbo temps, position of banjos, you cans just bend the hose to your needed location both banjos would really need to be pressed into the hosing at they're mounting angle - you could get around this by putting in a swivel fitting at the Cost of another £10, availabilities of correct size banjo bolts.
To cut an even longer story short I ordered one from tuning developments for peice of mind, and it was the best decision i made. The hosing company even told me its not worth the risk it'd work out roughly the same maybe even more expensive and was something that is essentially a gamble.
Hope this helps
Tuning developments is who supplied me with my oil feed, (don't run waters) other than that I think racetech do also and I'm sure race tech were doing a group buy in they're section on here which was really cheap iirc.
