i just fitted my corolla manifold and the engine wont start at all!!
my check engine light goes on and my oi light goes on, my oil temp shoots to the top when turning the key.
anybody any suggestions?!
help me out guys i am really bummed
there is an earthing point not connected,
on the back of the manifold there is an earthing wire, it sounds like you forgot to hook it up,
do any dash lights come on when you switch on the ignition???
checked it out and is ti a wire that has a couple of smaller wires (brown and white with blue stripe) caus it was a bit loose. i tightend the bolt up.
when i swith the ignition oil light jumps on and battery light to
when is switch of my oil temp meter shoots to the top and slowly goes back down again...
ow and i reseted ecu bye disconn. battery for half an hour...
why do this kind of things always happen to me..
The exact same happen to us when we fitted the inlet to my brothers old car, the earth. Where have other guys connected it up out of interest?
still doesnt work :)
could i connect the earth to some other part like the chassis or must it be the inlet manifold?
hope i get it running today still..
It has to be on the inlet mani, cause the friction from the air will create static, this is why we have the earth!
Make sure that no other wires are touching the inlet mani, that shouldn't be!
You could also check to make sure that you haven't accidently pulled sommit loose, check the surrounding wires and tubes!
hope this helps
hope this helps
earthing point not connected thats what my one was i put it on the Throttle body works a charm
tintin
just hooked up earth to throttle body.
took a few chrunchy goes but she fired up!!
thanks for the great overseas help!!!! u guys rule!!
one more thing:
only when i give a sudden shot of throttle it well.. *blurps* and misses a few fires it seems.. even stalled it once like that. didnt drive it yet just in neutrall and then i rev it.
also for a short moment the engine error light lights up.
is that caus she is getting used to her new longs or is there something else going on?
when i accelarate slowly it holds revs nicely and sounds great with my CAI
*EDIT*
tried to take it for a spin but could hardly get of my driveway..
moment i even just try to release my clutch she starts shocking and sometimes stalls
she runs idle perfectly..
prb solved guys just rechecked al cables didnt find anything but runs good now and what a sound + perfomance imporvement!!!
