The story!
Driveshafts were knackered so got some off here, changed over and the abs light came on. Throught the code for sensor. The abs ring was a smaller size on the new driveshafts... Random!
So changed the abs rings and abs light went off however now when I drive slowly I hear a noise like a steam train starting to move, cho cho choo..
It also also makes this noise is going to the right like round roundabouts!
wip the wheel off... If im right... the thin metal shield will be rubbing on the disc... When you speed up you cant really hear it... only really noticeable at slow speeds..
You'll be able to bend it back with your fingers there only thin metal.. Hence how you may have bent it...
