bajansuperman Posted February 4, 2013 Posted February 4, 2013 http://speedvisioncps.com/index.php?main_page=product_info&cPath=41&products_id=63 are those new r the same as the second gen which were shit Quote
AdamB Posted February 4, 2013 Posted February 4, 2013 Don't think anyone has tried them tbh, after all the shit with the last batch kinda puts people off. Be better off buying some Ivan Tighe cams which a lot of people use and have been spot on. Quote
bajansuperman Posted February 4, 2013 Author Posted February 4, 2013 Don't think anyone has tried them tbh, after all the shit with the last batch kinda puts people off. Be better off buying some Ivan Tighe cams which a lot of people use and have been spot on. is there a wed site that i can view info on these cams Quote
AdamB Posted February 4, 2013 Posted February 4, 2013 LIFT DUR. OPEN CLOSE AREA Lobe I1 ----- ------ ----------- ----------- ------ Centerline 12.00 ATDC 0.004 340.79 66.10 BTDC 94.69 ABDC 27.72 Runout 0.00000 0.006 315.05 52.65 BTDC 82.40 ABDC 27.66 Lift @ TDC 0.0621 0.010 273.10 29.43 BTDC 63.67 ABDC 27.50 Valve Lash 0.0080 0.012 264.46 24.18 BTDC 60.29 ABDC 27.45 Rocker Ratio 1.00 0.014 259.48 21.46 BTDC 58.02 ABDC 27.42 Lobe Separation 114.0 0.016 255.74 19.44 BTDC 56.29 ABDC 27.39 Minimum Flat 0.018 252.64 17.77 BTDC 54.87 ABDC 27.36 Follower Dia. 0.9271 0.020 249.97 16.31 BTDC 53.66 ABDC 27.34 0.040 232.41 6.94 BTDC 45.47 ABDC 27.08 0.050 226.01 3.60 BTDC 42.42 ABDC 26.94 0.100 199.58 9.94 ATDC 29.52 ABDC 25.96 0.200 147.44 36.08 ATDC 3.51 ABDC 22.02 0.300 82.97 68.28 ATDC 28.75 BBDC 13.86 0.35098 --- PEAK CAM LIFT --- 0.34298 --- PEAK VALVE LIFT --- LIFT DUR. OPEN CLOSE AREA Lobe E1 ----- ------ ----------- ----------- ------ Centerline 116.00 BTDC 0.004 341.75 114.40 BBDC 47.35 ATDC 27.69 Runout 0.00000 0.006 316.05 100.90 BBDC 35.15 ATDC 27.63 Lift @ TDC 0.0322 0.010 273.23 77.47 BBDC 15.76 ATDC 27.46 Valve Lash 0.0120 0.012 264.60 72.25 BBDC 12.35 ATDC 27.42 Rocker Ratio 1.00 0.014 259.51 69.45 BBDC 10.06 ATDC 27.38 Lobe Separation 114.0 0.016 255.73 67.40 BBDC 8.33 ATDC 27.35 Minimum Flat 0.018 252.61 65.71 BBDC 6.90 ATDC 27.33 Follower Dia. 0.9361 0.020 249.92 64.28 BBDC 5.63 ATDC 27.30 0.040 232.20 54.90 BBDC 2.70 BTDC 27.04 0.050 225.83 51.58 BBDC 5.76 BTDC 26.90 0.100 199.35 37.95 BBDC 18.60 BTDC 25.92 0.200 147.32 11.97 BBDC 44.64 BTDC 21.99 0.300 82.62 20.31 ABDC 77.06 BTDC 13.80 0.35102 --- PEAK CAM LIFT --- 0.33902 --- PEAK VALVE LIFT --- Excuse any miss-alignment issues, was copied from a document I have. Last time I checked they were $820 AUD Quote
