Fuel rail is the same, fuel pressures are the same that includes turbo models. Injector changes still havnt been proven, all still butt dyno tests. No-one including myself can confirm 100% what the flow rates and specs are.
I had jap 4x4 pink injectors in my uk car and whilst it 'felt quicker' my nose and ears told me it was runnin rich and near flooding at idle.
All partnumbers of all toyotas can be found at www.toyodiy.com Simply select the country model year etc
You want the early pre 1995 uk 4efe corolla
Edited by rmsnoel
Are you looking more mpg? If so just fit a corolla tubular inlet manifold and keep everything else standard. Then drive between2300_2900rpm all the time. 45mpg easy
yes better mpg is always good to hear lol and i want the corrola inlet is next on the job list to do or just engine conversion to a 1.5 ?? as mine needs cambelt clutch and piston rings doing :(
Dont be so keen to throw money at her lol. If the rings are gone well theres nothing to be gentle abput. Drive the livin death out of it. 1.5 are way over valued because of the popularity.
low milage scrappage scheme granny spec statlets are my favourite Place to get engines. All 30_45k miles.
Does anybody actually know the cc of the brown injectors and our own green injectors andthe ohms?
Partnumbers are written on the side of the injectors.
