I am just wondering how much it would cost to get a second hand td04 kit or is their a cheaper alternative than buying the kit for £1300 off tuning developments
Sorry if i posted this in the wrong area i wasnt quite sure on were to put it.
thanks Rhys
From what I've read;
TD04 compatible manifold.
TD04 turbo.
Oil feed/return line kit as apparently the TD04 lines are longer or different.
TD04 compatible downpipe.
Your intercooler piping won't work straight off so you'll need some piping made.
That's what you'll really need. What you should invest in;
Stand alone ECU such as GReddy E-Manage, Power-FC etc.
Boost controller such as GReddy Profec B, AVCR etc.
A remap would be advisable.
And I'd say an external Wastegate, helps with boost control, no wastegate creep etc. you'll need to weld your Wastegate flapper shut for the internal, and you'd also be better off with a screamer pipe, rather than having those exhaust gasses exiting inside the engine bay.
A filter relocation kit would be much better to avoid heat soak too.
Anyone want to add in some info?
So what you mean just cut the intercooler pipe more and kinda get a oversize silicone pipe and clamp it down tighter on the intercooler side?
Okey thanks Ricky
