starletburkie Posted February 13, 2013 Posted February 13, 2013 just fitted my td04 kit with turbosmart 38mm ex wg, it had 2 springs inside to mate it 14psi so i removed one, one was small and one was big so i removed the big one, it creeps from 0.5 bar upto 0.7 bar trew the revs, any way to stop that? boost controller is set at 0 and so is the gain Quote
starletburkie Posted February 13, 2013 Author Posted February 13, 2013 its a 7psi spring should be enough for a bar Quote
AdamB Posted February 14, 2013 Posted February 14, 2013 (edited) How are you reading boost pressure mate? From a gauge or the EBC? What brand is the gauge and EBC? Edited February 14, 2013 by AdamB Quote
starletburkie Posted February 14, 2013 Author Posted February 14, 2013 blitz gauge and dsbc, both are accurate mate would it be that the controller is not set up and its just wg spring pressure? Quote
AdamB Posted February 14, 2013 Posted February 14, 2013 (edited) Have you tried removing the EBC from the situation and just run base spring pressure bud? If your running 0 gain anyway I doubt it will be the controller. Have you turned the boost down to 0 on the dsbc or have you switched it to the - - - - position as this is technically off. Edited February 14, 2013 by AdamB Quote
starletburkie Posted February 16, 2013 Author Posted February 16, 2013 (edited) sorted now, there was two springs too make it 14psi, i removed the long one so only had the short one and it had the boost all over the place, swaped it for the longer spring and its sound now Edited February 16, 2013 by starletburkie Quote
