A mate of mine was planning this. Apparently the subframes are often known for breaking under load though :/ unless silly strong
That happens in C20LET Novas aswell, usually they just get welded up with an additional brace.
On are you going to need a lengthened fiberglass front end? Similar to whats needed when you do a B series conversion. My mates mini VTEC was an animal, but it did need a lengthened front end to fit it all in and that was only a B16!
very tempting project, the mini shells are going for stupid money now a days even for the rust buckets.
have to look into this further
thanks for the replys
i.work in.a classic and bini specailist some of the 2.0 ones go like stink and we supercharge the a series engines etc they can get the power down just as good
Tried fitting the 4efte engine into the mini subframe i have on the Demon but it was stupidly tight, don't get me wrong if you have plenty of time you can get them to fit but i decided to widen the mini chassis in the end to get it all in with a bit more room to spare. Glad i did as now i have a wide ass on the Demon and it looks alot meaner and should be a little more stable.
Seen a few of them in a Mini though and yes they go Very well :D
